- 20 Feb 2009
- Ashton-Under-Lyne
I'm considering upgrading to a 3 screen eyefinity setup, but wondered if the new 6000 series cards supported 3 monitors connected via DVI or 2 via DVI and a third by HDMI. I know the 5000 series doesn't allow this, and you have to connect one via the DP connector, but I don't know if this is the same for the 6000 series or not (if it is, and I go ahead with it, I would probably just get a DP>VGA adaptor)
On another note, which do you think is better?
Option 1:
T260 (26" 1920*1200 central monitor), 2x VX922 (19" 1280*1024 sides)
HD4870 powering the centre and a side, and the other side powered by a USB adaptor (I don't game on the USB connected monitor)
Option 2:
3x24" 1920*1080 monitors, powered by a 5850 or a 6870. Selling all the other monitors, gfx card, and USB adaptor.
I know the second part is probably better of in the monitors forum, but I thought I would add it on the end here anyway.
Option 1:
Option 2:
