- 26 Oct 2002
- Norwich
Gas is cheaper to heat the house with than electricity though
My friend measured his big Plasma screen and found it drew 750W
My dad had one returned to his shop because the customer didn't realise how much it was going to add to their bill, and found it was doubling the amount they had to put on their PAYG meter.
They are shockingly thirsty compared to LCD screens. Yours must be tiny if it only draws ~150W
On topic, I think the single most effective thing you can do is to double the amount of insulation in the loft. If you don't use the loft much just roll out another thick layer of fibreglass insulation on top of what's already up there.
I assume he has that 100" Panasonic one or more likely he cant work the meter.
Plasma barely draws any more electricity than LCD - the big difference is that LCD/LED draws a constant amount the only variable is how high you have the backlight up - the brighter it is the more power it draws. Plasma is variable draw, if its rated with a 500w psu it will only draw 500w when the whole screen is white and the brightness is at 100% - when watching normal tv it will probably draw 1/4 of the rated W
I measured my old 42" Panasonic PHD6 and it averaged 140w I also measured the nasty 7 series Samsung LCD i had for a week and it drew just over 100w constantly.
All of this OMG MY BILLS DOUBLED WHEN I GOTZ A PLAZMA is rubbish, bare in mind a 65" Panasonic 3D set is rated at 581w and in an AVF test it used between 80w and 430w depending on what was on the screen you can see that your mates was not using 750w and that while LCDs use less there is not a huge gulf in energy use and the yearly difference in energy costs is negligible and well worth it of you want the best PQ etc.
Onto energy saving, i find that the more you do the less of an effect it has on a house that was not built to be energy efficient in the first place - we have now got an A rated boiler, loft insulation at 300mm (where ive finished it) cavity walls insulated and on some odd bits that are single skinned (Bungalow and porch walls are single skinned for half a meter into 2 rooms we found) put some celotex inuslation on and boarded plastered over, new double glazing, energy bulbs etc etc still its not going to rate very hig as its a 1950s bungalow!
And then there is all the tech in the house, lots on all the time - in the end you always pay for fun
