Hi Guys,
Just rebuilding my own PC and want to use the old components in a PC I am building for my mum.
My old MB is a ASUS P5N-E SLI with 2GB RAM. To keep things cheep I was looking at the following Case OcUK Poseidon ATX Tower Case - Black (400W PSU). The thing I am not sure of is if the PSU that is installed in the case will work with this MB?
http://www.overclockers.co.uk/showproduct.php?prodid=CA-023-OP
The MB PSU requirements are :-
ATX Power supply (24 pin and 4 pin 12V plugs). ATX 12V 2.0 compliant
And the case PSU specs are :-
ATX 400W (20+4)
I know in my old setup I had 2 leads plugged into my MB, a 24 pin plug and a 4 pin plug.
Can anyone advise if the case PSU has both connectors?
I also plan to use this GPU if that makes any difference :-
Gainward GeForce 8400GS 512MB DDR2 PCI-Express Graphics Card.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-132-GW
Thanks in advance
XG
ATX 400W (20+4)
Thanks in advance
XG
