Advice on selling an LCD TV
3 Jan 2009
I've got a 20" Samsung LCD with about 4 years left on a 5 year warranty from a major high street AV retailer, comes in it's original box, all original leads, remote control (with batteries) and an antenna, that I'm planning to sell but I've no idea what it's worth:
20" Widescreen
Built in Freeview and analogue receivers
Brightness 300cd/m²
Contrast Ratio DC 10000:1
Resolution 1680 x 1050
Response time 5ms
Viewing Angle (Horizontal/Vertical) 170˚/160˚
Colour supported 16.7M
Video Signal Analog RGB, DVI, HDMI, Component , TV (Digital TV / Analog TV)
Sync. Signal Separate H / V, Composite
Connector 15pin D-sub, DVI-D, 2HDMI, Component, DTV Tuner, Optical Out, Scart, Cl Slot
Power
Power Consumption 50W (Max.)
Standby Power (DPMS) < 2W
Plug & Play DDC2B
Multimedia Speakers 3W x 2Ch (SRS TruSurround XT)
Special Features Built-in DTV (DVB) Tuner, Sound: SRS TruSurround XT. Optical digital sound (SPDIF). Component, HDMIX2, Supporting 1080P Input, CI Slot
Mac compatibility Yes
Cabinet Colour Rose Black
Accessories Remote Controller, D-Sub Cable, DVI-D Cable
Product Dimension (With stand, WxHxD) 486 x 417.5 x 215mm
Product Dimension (Without Stand, WxHxD) 486 x 350 x 86mm
Shipment Dimension (WxHxD) 559 x 493 x 152mm
Product Weight 5.6kg
Shipment Weight 7.5kg
Original box and packaging
Manual
Remote control (including batteries)
Power cable
D-Sub Cable
Simple antenna
I've found a couple of major online retailers that are still selling these for £200 which seems far too expensive for a 20" LCD.
Any idea what this is actually worth?
I can't get more than £200 for my 32" Panasonic which still has 3 of it's 5 year warranty.
TV's depreciate like cars I'm afraid.
£100 tops, also before you hang your hat on the warranty as a selling point, have you checked that it is transferrable if sold to someone else? They are often not, being valid for the original purchaser only.
