Don't agree with what I've said? I'd be interested to hear why you feel an engine that isn't maintained as well, run from cold several times a day and smokes up and down the motorway at a constant rpm is going to be in any better condition than one being used hard all day every day for a few weeks.
OK. I'll bite.
"Isn't maintained as well" isn't something we can't quantify easily here as we aren't in posession of the full facts. We know the brakes are changed but we don't know if oil/filters are changed at all or with what frequency or grade of oil.
We do know that the cars are subjected to 6ish hours of being driven as hard as possible, so we can safely assume WOT during all acceleration as well as deceleration just as hard as can be managed. Zero mechanical sympathy is shown to the cars, they are thrashed regardless.
Across an average lap, we could safely assume that the average engine state is somewhere between 4,000 and 6,000 RPM at wide open throttle, depending on driver skill. So thats 6 hours of sitting at likely double the RPM of the motorway car whilst outputting maximum torque. Being stock cars, they have no upgraded cooling parts or extras to help them cope with such output so the oil will be running out of spec, the coolant system strained to its limits etc etc.
Contrast that to the motorway car. Started in the morning and driven for the same 6 hour period. During that time both cars have gone through one cold start cycle each and run for the same duration. The engine will be up to temperature within minutes with a short burst of WOT to get up to motorway speeds (compared with the VXR car that has been thrashed when cold around a track!). It will then sit there at a constant speed in top gear at 2-2500RPM. Oil will be in spec, coolant system unstrained, no sustained exposure to high torque outputs.
Even internally to the cylinders, a WOT burn event is very different thermally to one at part throttle so the stress on the faces of the cylinders/pistons/valves etc are all reduced. Critically, the exhaust output temperatures will be lower, reducing wear on the turbocharger (which in turn reduces wear on the oil). On the motorway, the car is unlikely to be on boost whereas on track the car will near constantly be on full boost!
We're still talking about just the engine here, we've not even started on the drivetrain or the rest of the car... should I go on?
