Just a few more things to tweak/add and I'll finally be done.![]()
Woop, can see my burning tower house thing on the right
Make sure your client has actually updated as well, check the version number.
Update @ 2010-11-01 13:00 Notch has confirmed a bug in the latest patch with lighting, causing servers to spiral to 100% CPU usage, which are then restarted automatically by ClanForge for safety reasons. We are hoping this problem will be fixed soon.
so if the server crashes this is why
As you say, I don't think there is anyone there, as the boat is in the part above it
Best bet is to go over there and just swim about![]()
I'm more worried about someone starting building there while I'm planning it out before starting to build![]()
Right I've got a new idea...
Assuming no ones built in it already if you have np I'll find somewhere else.
I just don't want to finish planning and then find someone's built there and have to look again![]()
This sounds like an ambitious project tefal.......count me in (if you need help).
Thoses who can't logon & the server is giving you the message not on whitelist then repost your player name making note of lower & upper case text in your players name.
If the server does not give the message not on whitelist then that is not why you can not logon.
I posted a list of all members that are on the whitelist a few posts back using the names that was given to me on this forum & in the same lower or upper case as given to me.
