Cheap mid exhaust fitting advise
30 Sep 2008
Looking for some advise on what you would consider an acceptable quote for fitting a mid exhaust on Rover 25.
I can get the part down the road no problem but its fitting it that the issue. Didnt mind doing the back box last year but really want a garage to do this one.
So before i pop (or blow :eek:) down to the local garages, Kwitfit, Halfords etc i wanted to get an idea how it could/should cost. Of course if anyone knows of a good/trustworthy garage in Nottingham then please speak.
Shouldn't cost much. Removal, new middle box, fitting and disposal on the Polo was £47 all in last time I had one done. Rear box was the same price this week.
Local garage offered £50 to fit the part mid+back exhaust (grrr) but they gotta make a living right?
My next issue is the leaking window cleaners/sprinklers. Filled up the reservoir, pressed the button, nothing comes out of back or front but you can clearly see a load of water coming from the back left wheel arch.
After alittle investigation i can see water tube running into the wheel arch but i cant get it because its behind the body work. I presume this is a MOT failure? If not il leave it. (had my gaffa tape ready as well :D)
