Normal collisions look something like this, its instant not gradual.
That's same size, same mass and same speed. This is not the case in real life.
It shouldn't matter as my point is its instant changes in direction and speed, angles change at impact, they don't slowly take up the energy and curve away, its hit and bam direction/speed change.
yes you are right but those changes can be minute, depending on mass and speed difference. get several in a row and you get what appears to be a gradual change, it is not. but that's what it looks like on film.
This.
Acidhell is right. Radiation, you are wrong.
My point is not wrong, i never said something can't turn from multiple collisions its just highly unlikely you would get so many coming from the right direction to cause it to keep changing direction, even then it woulnd't be a perfect curve but a series of angle changes, thats not what we see, we see something that moves as if under some force.
But if you rae far enough away from it and it is constantly getting hit by very small forces which subsequently change its direction very slightly, it will appear to move in a curve.
And the non-believers come up. Good God, honestly. You must be completely wooden to think we're alone in the universe and that we're the fastest-evolved species.
can you imagine the panic and disturbance if they just popped on the whitehouse lawn?
there has been contact and us and them will slowly bring it into our conciseness .
it's not a small curve, a lot on your video get instantly tighter or straighter.
You need much more info to rule it out, until then it is the most likely explanation.
You say it's unlikely, you are dismissing it's perfectly possible to get streams of particles in space. Most likely from the shuttle itself. There's also streams of light and radiation from the sun, although I doubt that would have enough mass to push dust sized particles.
You do realize how many and how unlikely even on a small scale it would take .
lolz at the people saying dust and ice....come on guys
i hear theres an alien base on the dark side of the moon and thats why we have never revisited because they made threats against the earth![]()
lol careful saying that. dmpoole will put you down because apparently the world would accept it as normal with no problems at all
