I wish to run two ethernet points to another room in the house, however, as the cables will be routed externally, can I get 2 cables encased in one sleeve, if that makes sense?
Also, what spec cable is best used outside and how much more expensive is it than standard cable.. i.e, would it be best to use normal cable with trunking to protect it from the elements?
Cheaper would be better but at the same time, I want it to look good and last a long time.
