AgreedProblem is Win7 is based on Vista anyway so any improvements you have Vista to thank for the groundwork.
Personally I had no issues with Vista especially after SP1,not to meantion drivers are now thick and fast for both Vista and 7 nowadays(remember you can even use Vista drivers on 7 at a pinch),so I would have to say its an improvement with older/slower hardware,however stability wise its the same for me since I had no issues in that area,boot times etc same for me since I have both Vista and 7 running sweet.
Some problems with Vista I would even put down to user error as well,believe me you would be amazed at some of the excuses I have heard where it turns out to be faulty hardware and not the OS,problem is everybody likes to blame Vista when most people don't have a clue what they are talking about.
Bottomline Win7 is an improvement on Vista with older hardware but Vista is still a good OS in its own right,anybody that says otherwise should not be building or using PCs and should stick to consoles.
Win7 is probably best OS so far by Microsoft IMHO ,I have high hopes for Win8 to be even better ,only time will tell if I'm right.
This is essentially how I feel about it. I used Windows XP x64 on a system that had full driver support, and it was great. I used Vista x64 on the same system, with full driver support, and again it was great. I always assume that people who had issues with Vista were trying to run it on hardware that was barely adequate for running XP, and were surprised when their 4+ year old systems ground to a halt under Vista.I had absolutely no problems with vista, and IMO 7 just feels like a refined version. Yes, Vista had driver problems on release, but that's as much down to the hardware manufacturers as anything.
#1 bad thing about W7 is how many goddamn mouse clicks it takes to change the date/time!
(I know, I know, you don't often need to do that manually - but I've got a longterm habit of using the calendar in windows clock to check what day of the week future dates are etc)
A turd on a stick would be better than vista , so win 7 doesnt have to do much to be better
Mind you it is still not stable enough for business/industrial use , after sp1 it might be.
XP was better than Vista.
