I'm starting to think I got a moody instructor and am being shafted.
Did you leave a Quality Street box on the passenger seat? If not then there's your problem
[TW]Fox;17703251 said:Thats because the brakes are tested on rollers..
I'm specifically after some educated opinion or perhaps people who have had a car with a frankly naff handbrake tested and still not even got an advisory![]()
[TW]Fox;17708056 said:A completely mixed bag of responses all round then!
It should be fine. As long as it holds the car it doesn't matter how many clicks. If they suffer from it then there's not a lot you can do about it really.[TW]Fox;17710457 said:I've been out and adjusted it. It still requires the same ridiculous effort to put the handbrake on but now takes 8 clicks instead of 10.
Great.
Mine is crap too on the volvo, and has always been, new rear brake pads did nothing for the handbrake, also needs to be pulled very tightly to keep the car still on a hill, I simply tighten the cable a couple of hrs before MOT or so and ignore it the rest of the year and park in gear...
I couldn't stand to read 5 pages about handbrakes, but does it have an LSD fox? If so rollers don't come into it, they take it out for a drive and use the little G-Sensor thing to measure the braking effort.
