Best Way to Remove Putty from Wooden Ceiling
24 Sep 2007
Hi Guys
I hope some of the experienced DIYers can provide some advice. I need to remove a hard putty like substance (not sure exactly what it is) from my ceiling (thin wooden boards, see pic below). What would be the best technique to use to minimise damage to the wood? I can buy new tools if necessary.
Thanks for your thoughts.
Wonder what that is, is the ceilign stcuk up and thats glue residue?
Is it rock hard, or still rubbery?
If rubber an exceptionally shapr knife along the line of the wood, basically like a plane to remove the bulk might be a start.
Will it leave a gap after removal or is it all excess, belwo the level of the wood?
There used to be a shower unit there, so I guess it might be adhesive of some kind. It is dark brown in colour and rock hard.
Thanks for the tips so far.
So, we think heat and scrape rather than just scrape?
What heat gun would you buy?
Thanks guys. :cool:
Mechanical removal is your only option imo due to the wood. I would use mallet plus chisel then sand and stain to match.
The only problem is that the wood ceiling is quite flimsy, so I could see mechanical removal being a problem as I could easy break or split the wood.
What are the issues with the heat gun? Is it that I would burn the surface of the wood?
Thank you
In my view there is a danger of that yes. To get the substance hot enough to make removal easier, you'll surely run the risk of burning the wood. Have you got any offcuts that you can test the heat gun on? The only way to know for sure is to try.
You'll end up bubbling all the varnish before it does anything to the gripfill. That's if gripfill is even affected by extreme heat, not sure if it is tbh.
Best bet is as suggested, to use a chisel. The widest chisel you have, or even a 2" plane blade would do the job. Go with the timber grain to do as little damage as possible. Try and keep the blade as flat to the timber as possible to reduce the risk of the chisel digging into the timber.
You will more than likely need to then sand the remnants off with some course open coat sand paper. Start with something like 80 grit then, 120, 180.
