- 3 Sep 2003
Hi guys!
While popping out to the shops to day in my 53 plate MK3 Mondeo I noticed that the engine oil warning light was intermittently coming on after the car had water temp had warmed up. The warning light only came on twice and stayed on for a second or two before going off.
Parked up in the carpark, checked the oil level, all OK. Oil warning light was not light on the way back home. Checked the oil level again after letting the car sit for 10 minutes after getting home, oil level just under max.
What is it likely to be? Oil pressure sensor? Oil Pump?
Cheers
Cheers
