- 7 Jul 2010
- London
Putting aside the fairly offensive comments on this thread about photographers. There are a few points to note.
It may be that if other people are planning on using the machine (which appears to be the case) that those peeople would prefer utilising OSX over Windows - whether due to familiarity, preference, or for some other reason then it makes sense.
The asthetic point seems to have been ignored, the machine will look good and is designed to fit in an environment where this is an issue, particularly if this is an operation designed to make money.
The Mac and PC versions of Adobe Photoshop have the same features but not everything has the same shortcuts etc (certainly in the past at least) as a result if the user is more familiar with the Mac layout then it makes sense to have a Mac.
The Mac has access to Aperture 3 which is a very powerful portfolio management tool and editor which shares many similar features with Lightroom 3. These products go about things in different ways and some people prefer Aperture to Lightroom. Aperture is only available on the Mac and therefore it makes sense to have the Mac.
Also, over time there is usually a lower TCO with Macs. In addition, the manufacturing process is relatively envirnmentally friendly in comparison with some other products, which is a relevant, albeit small consideration to be included in the mix.
There is nothing wrong about the functionality of the Mac for this purpose, and no reason other than cost which should be brought to bear against the purchase of a Mac for a studio.
