Volvo V40
You've never driven 205 GTi have you? :D
I had Peugeot 205/306 in my head when I typed 'normal FWD car' :D
Those two are notorious for it. The Volvo V40, like pretty much everything else, isnt. It just seemed quite funny how he said the handling is ok because you dont get oversteer.
Driving 10-15 kph over the limit is hardly a big offense, after correction it's 3 or 4 tenners when caught... Nor is 30 mph an acceptable limit in many places. All the speed limit propaganda from the governments in the past decade is absolutely ludicrous. Look at countries with higher speed limits, it works fine there...
Tell that to the kid you run over.
There's a lot more about the handling, as long as you don't pull your wheel like a moron ( like 90 deg in a fraction of a second ( rather than gradually over say 1 second) at medium-high-ish speed) it will have LOADS of grip.
Kid's are usually in bed at 11pm & later. In some countries there's actually a higher speed limit at night in built up area's which should be everywhere imo.
There is no hope for you son, good luck.
I'd like to say the same too you, filled with anti speeding propaganda... I'm just annoyed why the NL can't have a law like in Poland that from 11 p.m. to 5 a.m the speed limit is higher in built up area's.
Luckily there is progress with motorways here though, the speed limit on motorways is going up :).
I'd love to see a road car which could turn its wheels to 90 degrees to the road :D
Sadly drivers such as yourself (This is from numerous other threads) are the reason those of us who enjoy our cars are often tarred with the same brush.
Why would anyone attempt to take a speed bump in a car they own at 35?
Because it's fun ? Same reason why you take your car to an empty carpark filled with snow to slide around a bit. Or floor it when coming on to the motorway.
[TW]Fox;17737458 said:
Driving over speed ramps at 35mph is fun?
It ruins your car, it isnt fun, it's just completely boneheaded.
Yeah, because you say so makes it a fact :rolleyes:.
It's not about the speedbump, it's a nice corner that happens to have a speedbump in it.
How???, have you no mechanical sympathy???
It's not a hard bump, bloody hell there are worse potholes in the road, it's not the same type of bump I earlier complained about which you can't take faster than at 10 kph, it's one you can probably easily take at 60mph without any damage. You know, the types you barely feel in some cars at all.
EDIT: you know, them Speed table type bumps.
yes but you have mechanical sympathy and avoid pot holes or slow down for them and dont deliberately drive down roads with unavoidable ones......
dont you ??
At 60 you feel running over a stone/catseye/whatever in the road, how the hell can you say you could hit a speed bump at 60?
:confused:
