Sorry one more question - if he goes iMac can you overclock them and if so whats the ideal processor (looking at cost too) to do this?
Thanks for all your adivce. As a few of you suggested its his clients that are important and will problably like the Macs more and feel more at home rather than use a PC. He has a warehouse with a photography studio when they can come and shoot pictures and then work on them too.
He needs EIZOs or prof grade monitors for them to use and also for his own use. He wants them so that they can be calibrated so that they can match the printer or something like that. What you see on screen is what you get on print I think.
Not sure how impressed his clients will be when they catch him with his wang in his hand2. You can look at "them" websites and not catch a virus
Not sure how impressed his clients will be when they catch him his wang in his hand
doesn't work like that.No you can't, unless you really sacrifice certain areas like using a bargain basement PSU or case. Then you might save £100 or so, whilst looking a lot worse. The 27" iMac really is a good deal, even if some poeple choose not to see that.
Same base spec, used good but cheapish components. As nice as the Lian Li it it won't look as good as the iMac. It's about £9 less than the iMac.
What's wrong with an LED backlight?doesn't work like that.
the iMac display is terrible. there are zero calibration, horribly saturated and it's got LED backlight. same IPS panel doesn't mean same image quality.
Are there any tests or reviews that show that the Dell outperforms the iMac display? I've always thought that LED are better is terms of both lifespan and power consumption but as far as how white they are, I'm not really sure how they compare. Are you saying a CCFL will also be bang on 6000k while an LED will always be slightly off?there is currently no perfect white LED, whereas CCFL have matured and offers perfect white, as far as sRGB and Adobe RGB colour profile are concerned.
with LED, you either get a yellowish screen or a bluish screen. there is currently no LED monitor that offers as good colour range as CCFL. that's why although Apple 27 inch and Dell U2711 use the same IPS panel, the Dell offers more accurate and wider colour range.
actually, RGB LED backlight will offer best of both world: wide colour range, and thertically lower power consumption. but none of Apple display uses it, Apple displays only use single coloured LED, fake white LEDs.
