You should check that your motherboard is capable of running memory at its rated speed (it will be part of the specification). a lot of i7 motherboards only rate their boards upto 1600mhz though in practice they go a lot higher.
Corsair cannot reasonably test the memory with every different, individual cpu. If your cpu has a poor IMC then surely that is Intels problem, not Corsairs? The fact that you have to compensate a poor IMC by adding excess voltage, is down to you, your settings, your motherboard or indeed Intel. Corsair cannot be held responsible for poor CPUs.
Corsair can only rate it's own product, if you don't have the equipment to run the product at it's rated speed then that is hardly their fault now is it?
My OCZ blades run at C7 2000MHz and they too need high QPI, as do most 2000MHz kits I have come across be it Corsair, Kingston, OCZ, Mushkin due to the frequencies involved and the IC's used. I'm not saying running a high QPI is harmless to your cpu but mine has been running at 1.5 for nigh on 2 years now (sometimes higher as it is the same one I used for my reviews) with no issues encountered.
In short the Corsair kit advertises a rated speed at a rated voltage, it does exactly what it says on the tin. This is of course assuming you have the correct hardware to compliment such high end memory kits.
