last spec check, buying probably tonight
23 Jul 2009
Shropshire
Any adjustments, apart form the need of a ssd.
thanks in advance
thats good.
the lite version of the case is only missing a fan and some graphics card support thingy? i think.
your also spending nearly £60 on fans, I know you need some for the cooler. but the other two?
Spec looks pretty bang on really, as above though, £60 on fans?!
Still if you have the money and aren't too bothered then go for it. Will be an immense system altogether :)
thats good.
Lite version of the case is only missing one of the top fans.
Could save a little money with that?
did the whole "lite" vs normal questions last month?
I never forget a face!!!!
Correct. I put a couple of questions in the News section of the forums.
And what? A Face? Mine? Where?!
Also, forgot. The Lite doesn't have the hot swappable drive at top of case.
and the drive bays are not all easy swap thingys,, and it doesnt include the multi gpu bracket thingy..
really need to learn the names of these things
