Minecraft OCuK Forum Members Server Thread
Apparently minecarts are still quite buggy going by the forums. Hopefully they'll get fixed soon enough. I still say we should start on the digging out of the areas needed, using TNT for the tunnels will make it very easy to dig 3x3 tunnels.
yeah but that's a lame way of doing it dig it manually :p (we'll need the stone anyway)
If anyones bored my 8 man server which is due to run out in 2 week i think is up and working.
Im just on making cobble machines and messing about with redstone,
If anyone wants to join give me a shout (dont want to give out the ip for someone to come put 20 carts in ;p)
i have a lot of tnt but i only use it for testing traps etc now p
one thing i would like to see implemented is the ability to lay red stone wire up a vertical wall would make things so much simpler than having to make steps for wires to run ip.
Tweet notch about it @notch
He seems to respond to most tweets he gets.
Wait wait wait....but surely you're going up a vertical wall to be able to go up a step? :p
Does it work on actualy stairs btw?
Also...i need to find some red stone, ive got about one block :p
It's like Rails, you put one on top and one on bottom and they link
I need some more too.. I gave most of mine away to Tefal so he could upgrade the ram on his double doors to play Day of the Tentacle on them.
Get your pick in gear, and build a 1:1 scale Large Hadron Collider !
edit: Or just tell people you already did, but forgot where you put it.
