Hi all,
I do some part time computer repairs and a customer of mine I am in the process of upgrading from XP to Win 7.
He has a hefty sum of files to transfer so I thought it apt to utilise the easy transfer tool... I saved everything that needed saving onto a USB hard drive (as you may know it saves as .mig01 .mig02 etc.)
Well everything has gone across fine except the pictures (of which there are 46 gbs worth of)...
It gets half way then says "Windows Easy Transfer can't open the Easy Transfer file. Make sure your USB device is plugged in or check your network connection."
So I thought I'd take the all the mig files off the USB HDD and put them all in a folder on the desktop which may work.
It gets half way through and says "Can't read from the source file MIG10" ... ... I wish I had done a manual backup of the pictures now - is there a way around this?
Please PLEASE help
Please PLEASE help
