- 13 May 2004
- Wales, Wrexham
Right, this is probably going to sound like a bit of a bizarre thread as it goes, but I'll start with what I have now, and what I want to / intend to do.
CPU: i7 920 @ 4ghz
Motherboard: Gigabyte EX58-UD5
GPU: ATI 4870X2
RAM: Kingston HyperX 6GB (3x2GB) DDR3 PC3-12800C9
Case: Zalman Z-Machine GT1000
HDD: 2x 150gb Raptor X (Raid 0)
HDD2: 1x 1TB Samsung F3
Sound Card: Auzentech Prelude
PSU: Antec Truepower 650w
Right, this computer as it stands is stupidly loud, and as far as I can figure out, the main culprit is the 4870X2 (Seriously, this thing when it starts to ramp up can drown out sound on my headphones)
My main aim in any of my plans is to reduce the noise output by a dramatic amount, though also hopefully help my gaming performance at high resolutions (2560x1600).
My first option was a simple GPU upgrade with perhaps an aftermarket cooling solution, I was going to do this with my 4870X2 at one point, but the Accelero cooler that is made for it is too big to fit inside my case, and I am thinking the likelihood is it will be the same with any other graphics cards at the moment, so am perfectly willing to purchase a new case and work from there.
Watercooling has been considered, although I am not sure how much quieter it would be than a good air setup, and am also not sure how confident I would be setting up such a kit, a new case would be required if i were to consider it, but it is still a serious possibility.
Now, as I have not purchased any upgrades for a relatively long time, I am perfectly happy with considering absolutely any new components, and am open to ideas with parts of my rig that I should drop (I am considering selling both raptors and simply getting an SSD of some description in their place)
Apologies if it sounds like I've been rambling, but what do you think my best options are?
edit - budget can be up to about £1k
Cheers
CPU: i7 920 @ 4ghz
GPU: ATI 4870X2
Cheers
