Which would you pick from these 2 options?
29 Sep 2003
Newcastle upon Tyne
The 2 choices are:
Core i3 processor with Intel GMA HD grapics or
Core 2 Duo with GeForce 320M.
The laptop would be used for all the basic stuff plus some light gaming (Sims 2, 3 etc).
Thanks
Michael.
The 2 choices are:
Thanks
Michael.
I would go for the Core 2 Duo eith the GeForce 320M, you probably wont get the Sims 2 or 3 working on the Intel HD graphics.
These prices are crazy, unless its a very thin and light machine.
The £850 is a MacBook Pro, the £600 is a Toshiba R630. I can't find any other laptop that is as thin and powerful as the MBP. If anyone knows where you can get a GeForce 320M laptop that is 2.5cm or less in thickness, and includes all of the same features as the MBP, for less than £850, please let me know as I'd be very interested!
Does thickness really matter that much? For £850 you could get a laptop that'd blow the MBP out the water. And it wont actually be that much thicker.
Yeah I want to keep the thickness under 2.5cm as I find thickness the main point in how large a laptop feels.
