From my own experiments, I found CoreTemp whithout any offset to read exactly the same as AMD Overdrive, right throughout the idle/load range. So yes they're definitely reading from the same sensor and interpretting the data the same. Trouble is, if CoreTemp and AOD are to be believed, my CPU max loads out at about 30C, LOL!Me? I've been comparing CoreTemp to the temps in HWMonitor and AMD Overdrive (both of which agree with each other). The display the Core temps and TMPIN0, TMPIN1 & TMPIN2 temps. I'm assuming (well, hoping) that TMPIN1 is the CPU temp.
The TMPIN1 temps are usually 12-15*C higher than the 'Core' temps.
