Bit different to the usual "spec me" type thread
11 Jun 2003
Sheffield, UK
Looking to build a rather small PC. Likely in a self-made case (only need mainboard mount + 4x3.5" drive bays).
What's the smallest mainboard with:
6 Sata (or 4 sata + 2 esata would be ok)
2x PCI-e (with the 1-4x slot above the grahics card)
The board needs to be able to take at least a 775 chip or better and have a 16x slot without restrictions on graphics card. Space for a decent air cooler needed too (tho tends to be less of a problem these days). I'm guessing it's one of the ITX boards but i've not seen any with the second slot yet.
The smallest board I've seen with 6 SATA is the Zotac H55 mini-itx boards. I don't think you'll get smaller than mITX with 6 SATA connectors as it's hard enough to find mITX with 6 SATA. Unfortunately it only has one PCI slot, but the WIFI is built onto the board so you wouldn't need a second slot for a network PCI card.
If two slots (and no more) are absolutely required then you're looking at getting a Flex ATX motherboard which only really come in Shuttle Barebones systems.
You appear to want a pci-e x16 slot which will handle any gcard. I think the other posters missed that. I don't know of any mini-itx board with a x16 gcard slot. I think the mATX is the smallest that meets your spec.
Just checked around. I was wrong in part. Tyan do a Flex ATX mobo with x16 pci-e but that only has four SATA..........:(
Removed
Removed
No promotion of OcUK's competitors
We, Overclockers UK (OcUK) are happy to provide the resources of these forums to responsible individuals without charge. They cost a substantial amount of money to maintain and use considerable amounts of bandwidth which is paid for exclusively by us. As you know OcUK are in the computer hardware business and therefore the promotion of OcUK's competitors is forbidden. Examples of promotion are :-
* Posting links to competitors websites
* Posting links to reviews that promote competitors
* Quoting the names or contact details of competitors
* Offering to provide the names or contact details of competitors
* Hinting about product availability at competitors and their pricing
* Using the forums to notify a member of intent or actual supply of names or contact details of competitors
* Listing competitors names, URL's or e-mail addresses in signatures
* Listing competitors names, URL's or e-mail addresses in profile
* Posting links to or the mentioning of auction sites
* Disguising attempts to do any of the above
