Personally I think flint should be banned just like TNT. It is to much of a risk especially with a lot of peoples structures being made out of wood.
I was not on-line when the incident happened but I will definitely help and clear up. I will also make a point of confiscating any flint Inputpow has personally, as he cannot be trusted ...
Flint in hand, trees near wooden houses, I'll burn them?
And seriously, why are even letting people on who have only just signed upto the forum (Unless of course the admins know them REALLY well)
Meh, this is the one reason I dont build with Wood atm, cause someone else will just come along and burn the thing down
It is actually quite useful when used responsibly, for example, I would quickly chop down the trunks of several trees leaving the just the bundles of leaves, set fire to those which clears them with no floating blocks of trunk material as this is chopped down in advance, this saves a huge large amount of time not having to chop away all the leaves individually leaving the ground clear for replanting. Also if you have some annoying animals trapped inside your structure, you can ignite the ground around them (lasts only a couple of secs) this is quite an effective way to kill them off.why are people using fire anyway, its not like it actually gets rid of trees (floating blocks) so just chop them down fs.
Flint in hand (lighter tool) should now no longer start fire on the server
It does not make any difference how long or how many posts a member has before they can join the server. I don't know any of you some of you have 10,000 posts & been a member for 8 years but.... I still don't know you & it does not make you anymore of a better person then someone who has just joined.
I ask players to be a member of the forums as it's my only very weak safe guard against players being a pain.
I can & will ban players but its very dangerous ground for what reasons I do give bans out.
Doesn't that mean theres no way to set fire now?![]()
well all the people who've siggne dup in this thread are friends of the people already playing who vouch for them.
I will be adding some rules soon on the first or second post on this thread.
Now the server is getting more busy & a larger player base is using it we are starting to get some issues that need rules to keep it a happy place.
That's Rad's treehouse, input. Well done in burning a house down again, and a forest full of trees AGAIN (they were also rad's). Oh, and well done for planting a load of tress outside my barn as well. That's real mature that.
How close do trees have to be to for fire to spread? Would have thought they'd all have to be touching.
