Nitefly I will do you a deal. If you give me some of your posts and I get you in the secret santa I will spend 20 pound on you to make up for last year?![]()
I have an idea of what to get, but I'm unsure where to get itGonna do a google search!
Found it. Hope nobody else puts one in. Is there a minimum the present must be worth?
Edit. I see you've written 10pounds. Does that mean I'd have to pay 10pound to enter, or the item I send in would need a value of 10pounds?
The item should have a max value of £10 not including P&P.
Max, as in things under 10pound are allowed?
Skippi, have i registered correctly?![]()
Well I can't see "SideWinder" anywhere in the accepted list, so I'mma go with...no.
Just edit your first name to include SideWinder.
