House Bannister
19 Mar 2010
Bradford, West Yorkshire
Long story short, I had to pull my bannister off the wall to get my couch upstairs (our living room is upstairs and door is downstairs....weird, i know!). The bannister was only attached, loosely, by 8mm(ish) screws that went straight into the plasterboard.
What i need is to be able to re-attach it for an apartment inspection on the 26th and then when we move out next June i'll need to be able to take it off and put it back on again to get the couch back down the stairs. Needless to say i need to make sure that the estate agent can't tell at any point ;)
So screw it back in? or are you saying you acutally ripped it off rather than unscrewing it so now you need ideas on how to get it back on and looking normal?
Screw it back on then, if possible into wood rather than plasterboard or use the existing fixings if you didn't do the utterly stupid thing of actually "pulling" it off the wall.
Yeah i ripped it out pretty much - there was no access to the screws at all from the front of the bannister. In my defense it was pretty much already hanging off, and, the estate agents initially told me we were OK to buy a new couch etc etc and then denied it so, they're the enemy ;)
I thought this would have been obvious (the screwing it back in part).
The ripping it off the wall part sounds a bit stupid.
Like i said it was already pretty much hanging off and there's no access to screws at all, they're attached to the back of the handrail/bannister which screw into the wall. There looks to be circles on the front but they're covered by wood - not just paint. The the screw heads are buried deep in there somewhere with a lump of wood which i assume is glued back in.
Man, I can't believe there's someone else on here pedantic enough to know the difference between a banister, a balustrade and a handrail.
Assuming you know what a balustrade is, I mean.
i'm not being pedantic, it is a handrail and yes, i know what a balustrade is, just wish more people would use the term
