Hi all
I am going to upgrade from a Q6600 to the AMD 1090T
As Above Can anyone spec me a half tidy ATX motherboard to suit this processor,I will not require SLI mode but i might consider a slight overclock if needed. Also i need new memory but i do not know what speed i would need until i have found a Motherboard.
I will be re-using with the new board:-
Zotac gtx 280 AMP
Asus Xonar D2 soundcard
Antec 900 case
Thermaltake toughpower 700W PSU
Samsung F3 103SJ 1TB
Western Digital 500GB SATA II 7200RPM
I would like to spend £90-130 on a board preferably, But what do you guys recommend please.
Also any tips on memory?
Leigh
Zotac gtx 280 AMP
Antec 900 case
Leigh
