Double din to single din kit? (VW Touran)
Blue wire used to be for powered ariels years ago and used to provide a feed when the radio was turned on. Presuming they still use the same colour still.
The blue wire is used to power the booster loacated in the factory mast, without this connected you will get a poor radio signal.
I've not seen any wires that look to pair up with that connection, would it be another blue wire I'm looking for?
Thanks,
G
Thanks,
G
You need to conect it to a blue antenna wire from the back of the HU, it should be labeled amplifier remote or power antenna, Rem / Ant :)
