What is this opinion based on please?
Many many years of experience and some bias towards nVidia.
6870 crossfire all the way.
Cheaper, cooler, faster, better scaling, quieter, MLAA, eyefinity.
470 are eol
- I run a dual monitor setup with 2 1080p monitors.
- Use my pc for design work primarily, using the adobe creative suit
- i play mainly WoW and SC2
- though i would like to dabble into some other games which are more demanding, including black ops, crysis etc
Go for the 470s if you want SLI
nvidia's multi gpu set ups have fewer problems than AMDs
There is nothing to back this statement up when comparing the 6 series to the 4 series. I have not seen any threads on here yet with people having any 6 series multi gpu problems. mybe i have missed them but i have not seen any.
I would concurr with sem - crossfire software wise has dragged behind SLI for years and theres nothing so far to indicate anything different. They do seem to have addressed some of the hardware issues with the 6 series, but ignoring the min/max/avg performance numbers SLI puts up more consistant performance in most cases with a far more stable baseline to the fps.
I have used both solutions and do use GTX470 SLI myself, I don't hide the fact I have a preference for nVidia but neither do I have any reason to go out of my way to try and discredit AMD/ATI, I'm just calling it like I see it from years of experience with PC hardware.
it is a know fact that when it comes to multi gpu support for games and bugs etc
nvidia and their drivers are ahead of AMD
470 are eol
Look at the results above rroff and tell me in crysis warhead which has the lower min fps out of 6870 crossfire and gtx470 sli. The last review i seen that went out its way with fraps during gameplay to see if this myth was true concluded that it was not the case at all a 5850 was giving better mins than a gtx470 at the time.
Have you got a link to this review mate ?
A quote from the introduction.
"Another reason why we wish to revisit this high-end graphics card battle is to settle a belief of green team fans that the GeForce GTX 480 is far superior to the Radeon HD 5870 when measuring minimum frames per second. This is an interesting argument as the average fps results did not suggest a huge difference in minimum frame rate performance when we last tested, though it could be possible, and therefore we wanted to find out if this was true or not.
However, simply showing the flat minimum frame rates is not enough considering that this could be the result of something else going on within the system that causes a split second drop in performance. Therefore we have recorded a frames per second timeline to reveal just how often the performance drops and for how long. Shiny new graphs coming your way, read on... "
http://www.techspot.com/review/283-geforce-gtx-400-vs-radeon-hd-5800/
These guys tested through gameplay not canned benchmarks to see if indeed the minimum frame advantage was a myth and thats exactly what was found that it is indeed a myth. We all know that canned benchmarks can be made to look good through drivers but gameplay does not lie. It looks to me during gameplay you would be hard pushed to tell the difference between the 2 company's if average fps was around the same.
Could it also be said that nvidia has had a performance advantage over the years so off course they will be better in the minimum frame rates. When the performance is equal though i don't think this is the case. This could be why nvidia fans percieve that nv has better minimum frame rates but in fact they don't its just that the amd card say 5870 is around 18% slower in the average so the gtx480 should automatically give a higher minimum.
Fraps runs can be inconsistent in themselves, playing through the game can bring up different results each time, at least with a canned benchmark you're guaranteed accurate results for each card.
Here is the same site with more recent results, notice how the 470 now has the much better min FPS than the 5850.
