What by posting a bunch of benchmarks without any power consumption tests applicable to each one?
Have a straw to clutch Rroff
I can show you for a fact those temp readings are wrong.
This makes me laugh... have you ever used or owned a pair of GTX470 SLI? I can put my hand on my heart and say I've used both options and can tell you for a fact that GTX470 SLI is not that noisey and definitely gives up the performance to make it worth the heat and power use.
Which Ati / 3dfx / matrox / powervr card have u owned?
Come on date and model?
Hmmmm u have jumped from one Nvidia card to another massive bias. And now ur giving the TS a skewed opinion about 470gtx.
If you really want to know cards I've actually owned myself:
ATI Rage II 3D+ somewhere around 1996
Voodoo 1
ATI Rage Fury 32MB
Riva TNT2 Ultra
Voodoo 3 2000 PCI
GeForce 2
GeForce 3 Ti200.
GeForce 5900XT
GeForce 6800
GeForce 7950GX2
GeForce 8800GT (SLI)
GeForce GTX260 (SLI)
GeForce GTX470 (SLI)
Another straw? Did you drop the first one?![]()
right if we take out the cards that
A) havent bought
B) that are not cards anyway because they are pre-installed on a laptop
Thats very poor, you havent had a single card apart from Nvidia since Geforce 2. Some 10 years you have been running Nvidia on your desktop for 3d and 2d cards.
And yet you trying to give a poster a unbiased opinion?
I had no end of problems with my 4870x2 and the crap drivers that was before it went faulty. I picked up a 470 as i have heard they are good. Cannot wait to try her out tomoz.
Impartial and objective mean pretty much the same thing, you are neither.
am I?
As I said - never pretended to be impartial, I think anyone with an open mind will find my advice tends to somewhat more objective than fanboy tho.
A lot more impartial and objective by a long long way than many here who are trying to hide behind the guise of being impartial - and quite blatantly haven't owned or used either solution.
objective [əbˈdʒɛktɪv]adj 1. (Philosophy) existing independently of perception or an individual's conceptions are there objective moral values?
2. undistorted by emotion or personal bias
