Recently fixed a problem I was having with my system and decided to start clocking my q6600 again and had it fairly comfortable at 3ghz with the ram at stock. The system was prime stable over night and cpu temps were around 55 to 60 degrees c under load.
I am not noticing any noticeable difference, in fact the system seems to be slightly clunky with the overclock compared to running at stock. I have had this CPU at 3.6ghz prior to an issue I was having with the graphics card which forced me to put everything back at stock before I diagnosed the problem. I didn't notice this "clunkiness" then, so my question is what possible cause could be making the system feel clunky when running the system at a faster clock speed?
What is all this talk of running the RAM 1:1 with the FSB? I thought it was better to run the RAM at stock for stability purposes. For the purposes I use this system I don't really need to overclock the system, that said I like the idea of having something for nothing.
FSX is much more responsive with the faster cpu clock speed but windows is just clunky. If I drag a window across the screen rapidly I have slight stutter when I overclock the processor but at stock its smooth and windows just seems more responsive.
Any ideas?
Motherboard is a Gigabyte P45-DQ6 and I have 8GB of OCZ 1066mhz DDR2 RAM.
Any ideas?
