INTEL MOTHERBOARDS INSTOCK: X58, P55, H55 and H57!
11 Dec 2005
Cheshire
Intel X58 Extreme BOXDX58SO(Socket 1366) DDR3 Motherboard @ £199.99 inc VAT
Today’s PC games and compute intense applications need a computing platform that delivers maximum multi-threaded CPU support and eye-popping graphics support. The Intel® Desktop Board DX58SO is designed to unleash the power of the 32nm Intel® Core™ i7 processor Extreme Edition with six cores and support for up to twelve threads of raw CPU processing power, triple channel DDR3 memory and full support for ATI CrossfireX* and NVIDIA SLI* technology.
- CPU Support: Intel Core i7 Socket 1366 Processors
- Chipset: Intel X58 Chipset with ICH10 Controller
- Memory: DDR3, Triple Channel Support, DDR3 - 1066, DDR3 - 1333, DDR3 - 1600, 8GB Capacity
- Storage: SATA 1.5/3.0 Gbps, SATA RAID
- Expansion Slot:1 x PCI (32 bit), 2 x PCI-E 2.0 x16, 1 x PCI-E x1
- Rear I/O: 1 x 10/100/1000 (LAN), 2 x eSATA 3Gb/s,1 x Firewire (6pin), 1 x Line In, 3 x Line Out, 1 x Mic In,1 x PS/2 Keyboard/Mouse Combo,1 x SPDIF Out (Optical), 8 x USB 2.0
- Form Factor: Standard ATX
- Accessories: ATX 2.2 compliant I/O shield, Low-profile right-angle SATA cables, 40mm LED fan with mounting bracket, Board and back panel I/O layout stickers, Quick reference guide, Intel® Express Installer driver and software DVD
- Warranty: 3 Years
Only £199.99 inc VAT.
ORDER NOW
Intel BOXDP55KG P55 (Socket 1156) DDR3 Motherboard @ £154.99 inc VAT
Designed by enthusiasts for enthusiasts, the Intel® Desktop Board DP55KG delivers incredible performance. Enjoy great over-clocking hardware and software while boasting new features like Bluetooth* technology. Support for ATI Crossfire* and NVIDIA SLI* technology rounds off the platform with amazing graphics performance.
Processor
At product launch, this desktop board supports:
Intel® Core™ i7-800 processor series in an LGA1156 socket
Intel® Core™ i5-700 processor series in an LGA1156 socket
Please see CPU compatability list for full range of supported processors.
Memory
Four 240-pin DDR3 SDRAM Dual Inline Memory Module (DIMM) sockets
Support for DDR3 1600+1/1333/1066 MHz DIMMs
Support for up to 16 GB? of system memory
Chipset
Intel® P55 Express Chipset
Audio
Intel® High Definition Audio? subsystem in the following configuration:
10-channel (7.1+ 2 independent multi-streaming) audio subsystem with five analog audio outputs and two optical S/PDIF digital audio for input and output using the Realtek ALC889 audio codec
Video
Nvidia SLI and ATI CrossFire technology support enables two graphics cards to work together for ultimate 3D gaming performance and visual quality
LAN support
Intel® PRO 10/100/1000 Network Connection (82578DC)
Peripheral interfaces
Thirteen USB 2.0 ports (8 external ports, 1 onboard, 2 internal headers)
Eight Serial ATA 3.0 Gb/s ports including 2 eSATA ports
Two IEEE-1394a ports (1 external port, 1 internal header)
Consumer IR receiver and emitter (via internal headers)
Integrated Bluetooth Technology Module
Expansion capabilities
One primary PCI Express 2.0 x16 bus add-in card connector
One PCI Express 2.0 x8 bus add-in card connector, bifurcated from the primary PCI Express 2.0 x16
One PCI Express 2.0 x4 connector
Two PCI Express 2.0 x1 connectors
Two PCI Conventional bus connectors
Form factor
ATX (12.00 inches by 9.60 inches [304.80 millimeters by 243.84 millimeters])
Only £154.99 inc VAT.
ORDER NOW
Intel BOXDH55HC H55 (Socket 1156) DDR3 Motherboard @ £79.99 inc VAT
The Intel Desktop Board DH55HC is an Intel H55 Express Chipset-based desktop product in full ATX form factor. It offers premium features such as the support of dual-channel DDR3-1333MHz memory with four slots up to 16GB, Intel High Definition Audio with 5.1 surround sound, and integrated Intel PRO 10/100/1000 Network Connection in a novel low-power design.
The board supports the Intel Core i7, Intel Core i5, Intel Core i3, and Intel Pentium processors. The board is featured with VGA, DVI-D and HDMI connectors and supports dual independent display for processors with Intel Graphics Technology.
The board also supports legacy features like PCI slots, parallel header and serial header, and back panel PS/2 connector to create a balance of legacy and premium features.
Processor Support
Support for the Intel Core i7,Intel Core i5, Intel Core i3, andIntel Pentium processors in theLGA1156 package
For full list of supported processors go to processormatch.intel.com
* Onboard graphics Requires Processor with Intel HD Graphics, currently I3-530/540 and I5-670/661/660/650 Processors
Chipset
Memory
Four dual-channel DDR3 DIMMsockets
Support for DDR3 1333 / 1066 MHz(16 GB3 max)
Graphics
(Requires Processor with Intel HD Graphics Technology)
VGA + DVI-D + HDMI output
Expandability
Six SATA ports (3.0 Gb/s), includingtwo onboard eSATA ports
Twelve USB 2.0 ports (six externalports, six ports via internal headers)
Two PCI Express* x1 connectors,three PCI connectors
Legacy Support
One PS/2 port
One serial port header
One parallel port header
Audio
Eight-channel Intel High DefinitionAudio4
Three stack analog audio ports
S/PDIF out header onboard
Front panel mic/headphone header
Internal speaker header
Connectivity
Integrated Intel PRO 10/100/1000Network Connection
Additional Features
Windows Vista* Premium WHQLcertified
Windows* 7 WHQL certified
Form Factor
ATX (9.6" x 12")
Only £79.99 inc VAT.
ORDER NOW
Intel BOXDH57JG H57 (Socket 1156) DDR3 Motherboard @ £92.99 inc VAT
There's no need to sacrifice performance with a small system. The tiny Intel® Desktop Board DH57JG fits into the space-saving Mini-ITX chassis, allowing you to experience great computing with many of the latest Intel® Core™ processors as well as Intel® Pentium® processors.
The Intel Desktop Board DH57JG also provides an unprecedented low-noise, low-heat home entertainment experience. This compact design has an integrated HDMI port for 1080p output support and ten-channel Intel® High Definition Audio with Dolby Home Theater.
Intel® Remote Wake Technology
Intel Quiet System Technology
Help reduce system noise and heat through more intelligent fan speed control algorithms.
Intel® HD Audio Technology
Intel has worked with the industry to develop a new specification for integrated audio that is capable of delivering the features and high-end performance of an add-in audio card. Intel® High Definition Audio (Intel® HD Audio) is capable of playing back more channels at higher quality than previous integrated audio formats. In addition, Intel High Definition Audio has the technology needed to support the latest and greatest audio content. By enabling enhanced usage models, Intel High Definition Audio, available with the Intel® Express Chipsets, will also change how computer users interact with sound.
Intel® Matrix Storage Technology
Intel Matrix Storage Technology provides new levels of protection, performance, and expandability in 2008 for desktop and mobile platforms. Whether using one or multiple hard drives, users can take advantage of enhanced performance and lower power consumption. When using more than one drive the user can have additional protection against data loss in the event of hard drive failure.
Form Factor - Mini-ITX
Socket - LGA1156
Memory Specifications
Max Memory Size - (dependent on memory type) 8 GB
Memory Types - DDR3-1333/1066
Memory Channels - 2
DIMMs - 2
Graphics Specifications
Integrated Graphics - Yes
Graphics Output - HDMI, DVI-I
Dual Display Capable - Yes
Discrete Graphics - PCIe x16
Expansion Options
PCIe x16 Gen 2.x 1
I/O Specifications
USB 2.0 Configuration (Back + Internal) 6+6
SATA - Ports - 4
eSATA Ports - 1
RAID Configuration - 0,1,5,10 & Matrix
Audio (back channel + front channel) - 10-ch
Integrated LAN - 10/100/1000
Only £92.99 inc VAT.
ORDER NOW
Interesting placement on the memory slots on the X58 board, does the ram modules with large heatsinks work ok with the Noctua!
Price on the first one is wrong. Just noticed the first one has a single black dimm slot and 3 blue ones, is it usually not 2 of each?
again, im going to wait out until they come out with pci 3.0/usb/sata 3 mobos. I was gonna upgrade some time soon but the current 780i/sli 9800gtx's/q6600/4gb pc8500 RAM, does me just fine at the moment.
The only thing im upgrading just now is to a SSD drive, and a new PSU and monitor.
