- 11 Aug 2010
- Cambridge
I want the x6
3) nope , not right. i've had 3 motherboards with a 965 and 1090t, the tmpin1 always reacts so more quicker then the "core reading"Well guys I think the thread is getting a bit confused now so for clarity I'm just going to tidy up my ramblings and leave it at that...
3) My own tests involving three motherboards and three CPUs show that the figures labelled "Core Temps" in HWMonitor react much faster than TMPIN0/1 to changing CPU loads. Conclusion: The HWMonitor "Core Temps" are reading from the "Internal CPU" sensor and TMPIN0/1 is reading from the "CPU Socket" sensor. Perhaps for AMD systems the writers of HWMonitor should relabel "Core Temp" as "Internal CPU Temp"?
4) AMD's own Overdrive software displays the same figures as HWMonitor "Core Temps". Conclusion: These numbers are important to AMD so they should also be important to us. They may display odd values but a bit of googling will reveal why. It's a scaled offset from some maximum value rather than an absolute reading.
5) The CoreTemp software also displays the same figure as AMD Overdrive "Core Temps" and HWMOnitor. If you go to their website, you can have a read of the FAQs concerning AMD processors. An offset needs to be applied to get a more meaningful reading. Trouble is that the offset varies from CPU to CPU and mobo to mobo. However, this is where TMPIN0/1 become a useful reference. Going back to point 2 above, you'd expect a fully loaded CPU (Prime95 etc) to have an "Internal CPU" reading a few degrees higher than the "CPU Socket". So you just need to apply an offset that gives such a result. For my machine this turns out to be about 20*C. With an offset of 20C, the "Internal CPU" temp runs about 5-6C hotter than the TMPIN0/1 reading. So Gareth, my way of monitoring the CPU temp is actually safer than yours as it turns out.
Now of course this is all utter rubbish because Gareth has had an email from somebody at AMD saying to "read the CPU temp"....
Thanks for listening.
Well I'd probably let it go to 71C on the internal sensor which equates to around 65C at the socket TMPIN0 on my Asus board. According to AMD, this 95W chip is good to 71C and like you say, they wouldn't set a figure on the cusp of death. But yeah, you get my drift.'cause he's not letting his go over 62'C on the internal sensor, around 52/55'C.
Well that is odd. Has anybody else experienced this?i've had 3 motherboards with a 965 and 1090t, the tmpin1 always reacts so more quicker then the "core reading"
Maybe he said that because he knows that TMPIN0/1 is easier to read BUT knowing that it is the socket reading had better make provision by saying it will be a few degrees out?he said it's the tmpin1/cpu reading that should monitored but he did say it'll be afew degrees out
Well no. The idea that the "Internal CPU" sensor is going to experience higher temps than the "CPU Socket" sensor is based on very sound thermodynamic principles. No?
That said, you are right in that my 5-6C margin is something of an educated guess. The problem gets worse with overclocking too as the delta from socket to internal temps will increase quite significantly. I really hope AMD sort this nonsense out with the next gen CPUs and include proper core temps.
But until then, if you're going to measure the CPU temp using TMPIN0/1 and compare it to the quoted AMD max temps, you are almost certainly going to exceed normal operating temps inside the chip.
Hey Rory,Hi everyone, my brother recently got a 1055t 95w edition and when we were overclocking it and running linx and prime the other day every time it went above 48c it would drop the multiplier down to x4 [x7.5]
his motherboard is a ASUS M4A78LT-M LE
The max temp generally for Phenom II's are 55-62c, that could very well just mean 55-62c CPU temps, and not core temps.
CPU temps? As reported by the "Internal CPU" sensor or the "CPU Socket" sensor?
Why do you think it's the CPU socket temperature that's being reported?
No, neither have I.Why would "CPU Temp" be the CPU socket temperature.
I haven't heard a reason WHY.
