Windows Environment on Mac
8 Dec 2004
Hampshire
Ok so continuing my journey into the realm of the unknown, could anyone shed any light on whats the best way to run Windows on a Mac? (I.e. I have heard of some emulation/virtual machine type software) Or is dual booting a better way to go?
Generall speaking for what main reasons do people revert to Windows on a Mac?
Also which version would you go for ? XP? Vista? 7?
These questions are probably blatantly obvious to most on here but please be gentle :D
Well tbh, nothing specific, but it would be nice to fall back on a familiar environment? :)
It would be nice to play some games which are not possible on the Mac? (How does parallels et al cope with this?)
I used to use bootcamp but gradually found myself using it less and less as time went on.
Recently I wanted to do somw work and Word for Mac is utter tripe so I looked at Parallels and its great for running windows programs in thier own windows.
I'd recommend VMWare Fusion over Parallels anyday as well, only because last time I used Parallels it just BSODed on boot after installing WIndows, I did the exact same install on VMWare and it worked a treat. I think VMWare has more to offer also, although I'm not sure what Parallels has changed since.
Bootcamp is the only bootable environment alternative to OSX.
Parallels and VMWare are both virtual environments.
If you are expecting good performance from your windows for games or similar use boot camp.
If it is for small low intensive tasks then use a VE.
Thanks all.
Can I ask in terms of gaming, what kind of performance defecit one should expect from using a virtual vs bootable environment for the same hardware?
E.g. say using an emulator of some kind and also say playing a non intensive 3D game. I dont know something like, one of the Lego adventure games?
Thanks all.
If your looking at playing games then you'd boot into the Boot Camp windows environment but with both Fusion and Parallels you can also startup your Boot Camp install as a Virtual Machine.
VMWare is a virtual machine environment. I don't do games, but do do some heavy number crunching on my machine (in Windows, virtualised), and it copes fine. Sure, it might be slightly quicker in bootcamp, but the convenience of being able to switch between OS on the fly is worth much more to me.
I run x86 Windows OS, as thats what I have, and I don't have enough memory or prgrams to take advantage of x64. VMWare fusion will support both.
