Permabanned
- 15 Nov 2008
There's a difference between reaction times and perception of delay. Reaction time tests measure the gap between seeing a signal, and enacting a response, but if the lag on your equipment is less than this lag time you can still perceive it as being sluggish.
Taking myself as an example, I've taken these tests before, and my reaction time is around 80-100ms in general. But still, anything over 20ms seems sluggish, and enabling vsync (on my 60Hz screen) makes the controls seem very sluggish indeed.
Well for starters youre obviously in that top 0.01 percentile that that test figures is impossible to reach, going on that test 200ms average I'll explain better where I was coming from
Whilst yes there is a difference agreed, your eye sees something on the screen, you react which takes 200ms, clicking the mouse, theres then an amount of lag from mouse input/screen image etc to take into account before your click registers, people claiming to be able to tell the difference between a 2ms and 6ms response time are claiming to be able to notice 1% difference (in addition to their reaction time) which is pretty impressive (read BS)
Yeah, by that logic having a 200ms reaction time would mean you wouldn't notice the difference between 5 and 10fps?
No, not really, the brain can process more information than it can react to thats all
