BenQ G2420HDBL 24" Widescreen
How does the Hanns.G HH251DPD 25" widescreen compare to those already mentioned?
I've used Hanns.G monitors in the past, they're pretty solid on the whole, but once I bought a Samsung monitor I realised how desperately uninspiring the panel in the Hanns.G was.
For the money, you get what you'd expect, a cheap panel put together fairly cheaply, but you still get a warranty. All depends what you expect from it and what you're using it for.
I haven't used it myself but considering the screen is larger and the price is cheaper... It isn't likely to offer the same level of quality as the Samsungs. That's not to say it's a bad screen.
Haha wary of a bargain? Just like myself :D
Thanks mate....and using it for gaming, gaming, gaming!
Probably the Dell U2311H, although that's 23" not 24"... the Dell U2410 24" is excellent by most accounts, but it's hardly cheap at just under £500!!
Jesus wept - I can't stretch to that lol. I was hoping for a few quid more than the TN panels I was looking at! :)
Thanks mate. If £100 is the cheapest comaprison to a good TN panel - I may have to compromise and just go for a good quality TN.
PCM2.
Today I purchased the Samsung B2430H based upon your recommendation.
It turned up in the OC 'B Grade' products for £129 and some pennies!
Many thanks for all your advice and help mate.
No problem - always a pleasure. Let me know how you find it when it arrives. :)
Will do buddy. I'm currently deciding which OC computer system to pair it with so it may be a week or two - but I'll report back :)
Due to a slight hitch at OC's end - I have paid a little extra and will end up with the Samsung P2450H.
Obviously I'm a little dissapointed at the extra cost - but hopefully the monitor is so good it makes me forget bout the money :)
I'll keep you posted how I find it, when it arrives next week!
Honestly don't think you would notice a difference in image quality. And the looks of that thing were so appealing to so many people that Samsung kind of brought it back from the dead. :D
Haha aww well - at least it's better looking!!! :D
