Hi all.
I've got a dual res setup with a CPU block and a motherboard block. Currently I'm thinking of having a dedicated water loop for my GPU too.
I'm not too sure if this will be the best loop:
Config one:
Res -> Rad (420mm) --> CPU --> Moboblock -->Res.
Res -> Rad (240 mm) --> Rad(140) --> GPU --> Res.
Config two:
Res -> Rad (420mm) --> CPU --> Res.
Res -> Rad (240 mm) --> Rad(140) --> Mobo block --> GPU --> Res.
I'm not too sure which config will be the best.
Config one:
Config two:
