I want my music louder!
Permabanned
7 Nov 2010
Everything is full volume! What can i do? I mean, audio is a processed thing, why does it have a limit? My dads old audio kit used to be able to blow speakers it you put it to max, how do I ramp up the volume on my pc so my music is really loud?
Put a feed into a multichannel amplifier with some proper speakers and a subwoofer. Then you can blast yourself to kingdom come. But do watch the volume if you don’t want to start going deaf.
Your amp needs to have a limit. If you could push 6000watts through your crap 75 watt pc speaker amp, it'll bring your house down, not with sound, with fire.
I'm prepared to have the fire brigade here if it means i get a minute or two of deafening music!
Basically i'm running from a laptop, is there no overdrive system? iTunes used to be able to use equalizer and turn music up double, VLC player makes stuff got up to 400%. I know these speakers have been louder, is there some hack that can make spotify louder, or win 7 louder? If i put my laptop charger into 400V will that work?
You can with most programs, I.E winamp, VLC etc.
It doesn;t sound great on laptop speakers but in desperate times.
Ugh, ok in the vague attempt at a sensible answer... are you connected to the headphones output or to a line out output?
If you tell the laptop that the 3.5mm jack is going to headphones you should get more control of the output volume I think...
Thats what I do, all in 7.2 channel glory. Onkyo 608, Kef 3005se Eggs, and 2 Kef 250w subs, Essence STX and away you go....if you want it louder than that then it power amps and monitors.
Hideous digital clipping hoy!
You need a more powerful sound system, simple as.
I KNOW BUT THIS DOESN'T HELP ME AT 10 PAST THE MORNING DOES IT?
Basically, is there any way to overdrive my system? I have linux that i can load up if that gives me the option to rape my speakers to death which i will do!!!
