Recommendations on a new CPU :)
7 Nov 2002
Glasgow / Canberra
Howdy
I have a box thats nearly 3 years old, with a C2Duo E4600, at 2.4Ghz, and with a lowly FSB of 800
that said, i am looking to upgrade it, but i havent really kept my hand in, with whats what, so am looking for some recommendations, or does it still hae enough grunt to go forward? please bear in mind, that the system this runs in, has to sit in a quiet room, so noise is a consideration.
ie. no overclocking!
thanks in advance
OK
Few questions
What do you use your computer for? As this can affect the recomendation
What is your motherboard? No point recomending an incompatible chip (download and run cpuz if youre not sure)
Lastly what sort of budget do you have in mind?
OK
Few questions
watching movies and games, although havent done gaming in a while, but i would like the extra ooomph, just incase.
i should have mentioned, if i get a new CPU, then i will get a new m/board and RAM also, as it will certainly be a different platform
Intel Core i5 760 2.80GHz (Lynnfield) (Socket LGA1156) - Retail Intel Core i5 760 2.80GHz (Lynnfield) (Socket LGA1156) - Retail £144.98
(£123.39) £144.98
(£123.39)
Asus P7P55D-E Intel P55 (Socket 1156) DDR3 Motherboard Asus P7P55D-E Intel P55 (Socket 1156) DDR3 Motherboard £98.98
(£84.24) £98.98
(£84.24)
Corsair Hydro H70 High-Performance CPU WaterCooler (Socket LGA775/LGA1156/LGA1366/AM2/AM3) Corsair Hydro H70 High-Performance CPU WaterCooler (Socket LGA775/LGA1156/LGA1366/AM2/AM3) £83.99
(£71.48) £83.99
(£71.48)
Corsair Dominator 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMD4GX3M2A1600C9) Corsair Dominator 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMD4GX3M2A1600C9) £70.49
(£59.99) £70.49
(£59.99)
Sub Total : £339.10
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £9.50
VAT is being charged at 17.50% VAT : £61.01
Total : £409.61
You could clock that at 3.8 - 4 with no noise issues, take off a tenner for free delivery and you're just under 400 bucks, theres loads of room to shave off a bit of money too!
What PSU does the OP have and what graphics card??
What games do they intend to play??
Does the OP intend to overclock??
The E4600 with its high multiplier should be able to hit 3GHZ at least.
Also,with Intel Sandy Bridge being released in January it would be better for the OP to wait until then, if they intend to change to a new platform.
