too big a job to tackle? Case suggestions please
6 Nov 2010
Behind the camera...
howdy :)
I'm thinking of modifying... well more like butchering my A380 case lol
I wanted to modify the rear panel so the PSU is at the bottom, rather than the top, but thinking about it, it would envolve quite a bit of work
I'd have to remove the rear panel, cut the PSU holder part off the top, weld that to the bottom, relocate the motherboard panel etc,
Ideally I think I need to sell my case and a new case is in order,
I'm after something that must be back inside and out,
decent cable tidy system like a motherboard panel with cable holes etc,
tool-less design and preferably ATX or only slightly bigger...
what are the suggestions please, pics too if you can :)
cheers
Depends what you prefer and if good styling matter as well as budget of course.
I would say the best case around the £60-£100 mark is probably the fractal design R3 in terms of performance user friendly and looks department.
do you mean this one?
abit bland for my taste, cheers anyway though,
Think i've decided on the Antec 1200 to be honest :)
Coolermaster CM-690 II Adv.
Great cable management, PSU at bottom, mostly tool-less and black in and out.
GOGO!! :D
I can second that, I just replaced my Thermaltake Kandalf LCS case with the coolermaster mentioned and it's a brilliant case, looks wise and practicality. I love the sata dock at the top, great for doing data recovery jobs.
