What about all the fats? best way to lose fat is to eat fat, and a lot of it.
Is it really? I never thought this would be true, so in hope of loosing fat, I cut fats out of my diet.
Some people say it does'nt work but loading with sugars and salt usually does the trick.
Is there any specific source that says its better to have it with carbs?
Supplementation resulted in an increase in muscle phosphocreatine (PCr), Cr, and total creatine (TCr; sum of PCr and Cr) concentration in groups A and B, but the increase in TCr in group B was 60% greater than in group A (P < 0.01). There was also a corresponding decrease in urinary Cr excretion in group B (P < 0.001). Creatine supplementation had no effect on serum insulin concentration, but Cr and CHO ingestion dramatically elevated insulin concentration (P < 0.001). These findings demonstrate that CHO ingestion substantially augments muscle Cr accumulation during Cr feeding in humans, which appears to be insulin mediated.
I don't like Creatine, i just don't like certain characteristics you get from it, the only part i like is the increased rate of power and strength because your Creatine stores are increased so you can train harder. I don't like the fact it dehydrates you so you have to drink more water, and i don't like the idea of the majority of your bulk being made up of water, due to the water retention which can lead to your muscles feeling soft.
darn i thought it was help you build more muscle and not just bulk it up by retaining more water??
darn i thought it was to help you build more muscle and not just bulk it up by retaining more water?? How will bigger muscles full of mater help you to lift bigger weights/increase strength?
how long should you use creatine.. to see noticable difference in terms of size and more importantly strength?
