*****OCZ Memory Weekend ONLY Deals - Truly Amazing Prices!!*****
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Got some cracking memory deals for you guys this weekend, truly massive discounts:-
OCZ Gold 12GB (3x4GB) DDR3 PC3-12800C8 1600MHz Triple Channel Kit (OCZ3G1600LV12GK) @ £234.99 inc VAT
Home CategoriesDesktop MemoryDDR3ValueGold SeriesOCZ DDR3 PC3-12800 12GB Gold Low-Voltage Triple ChannelOCZ DDR3 PC3-12800 12GB Gold Low-Voltage Triple Channel click for high resolution image
Description Specifications OCZ DDR3 PC3-12800 / 1600MHz / 4GB Modules / Gold Edition / 12GB Triple Channel / Low-Voltage
Addressing the never ending need for greater amounts of system memory, OCZ’s newest Gold Series 12GB Triple Channel kits support the latest memory-hungry applications and games, offering superior performance gains and maximum multi-tasking productivity. Ideal for workstations with 64-bit operating systems, the OCZ 12GB solutions allow users to take advantage of high density memory configurations when working with intensive design and multimedia applications.
The Gold Series 12GB kit is designed specifically for the Intel® Core™ i7 processor / Intel® X58 Express Chipset. Optimized for the Core i7’s triple channel mode, these new 12GB kits ensure optimal performance via an ideal combination of low voltage requirements, speed, and latency.
OCZ Triple Channel solutions are the choice counterparts for leading-edge performance that won’t inhibit the functionality of Core i7 CPUs. In addition, modules are tested in matched triplets ensuring superior compatibility. All Gold Series kits are 100% hand-tested and backed by the OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
Features:-
- 1600MHz DDR3
- CL 8-8-8-24 (CAS-TRCD-TRP-TRAS)
- Unbuffered
- Gold Layered Z3 XTC Heatspreader
- Optimized for X58 Chipsets / Core i7 processors
- 1.65 Volts
- 240 Pin DIMM
- Lifetime Warranty
Was [£299.99] Inc. VAT
Only £234.99 inc VAT.
ORDER NOW
OCZ Platinum 12GB (3x4GB) DDR3 PC3-12800C7 1600MHz Triple Channel Kit (OCZ3P1600LV12GK) @ £281.99 inc VAT
Addressing the never ending need for greater amounts of system memory, OCZ’s newest Platinum Series 12GB Triple Channel kits support the latest memory-hungry applications and games, offering superior performance gains and maximum multi-tasking productivity. Ideal for workstations with 64-bit operating systems, the OCZ 12GB solutions allow users to take advantage of high density memory configurations when working with intensive design and multimedia applications.
The Platinum Series 12GB kit is designed specifically for the Intel® Core™ i7 processor / Intel® X58 Express Chipset. Optimized for the Core i7’s triple channel mode, these new 12GB kits ensure optimal performance via an ideal combination of low voltage requirements, speed, and latency.
OCZ Triple Channel solutions are the choice counterparts for leading-edge performance that won’t inhibit the functionality of Core i7 CPUs. In addition, modules are tested in matched triplets ensuring superior compatibility. All Platinum Series kits are 100% hand-tested and backed by the OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
Features:-
- 1600MHz DDR3
- CL 7-7-7-24 (CAS-TRCD-TRP-TRAS)
- Available in 12GB kits
- Unbuffered
- Platinum Z3 XTC Heatspreader
- 1.65 Volts
- 240 Pin DIMM
- Lifetime Warranty
Was [£329.99] Inc. VAT
Only £281.99 inc VAT.
ORDER NOW
OCZ Gold 6GB (3x2GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Triple Channel (OCZ3G1333LV6GK) @ £82.24 inc VAT
The OCZ PC3-10666 triple-channel memory kit is designed specifically for the Intel® Core™ i7 processor / Intel® X58 Express Chipset. Optimized for the Core i7’s triple channel mode, these new 3GB, 6GB, and 12GB kits ensure optimal performance via an ideal combination of low voltage requirements, speed, and latency.
Developed for enthusiasts and early-adopters, the low voltage OCZ Triple Channel solutions are the choice counterparts for leading-edge performance that won’t inhibit the functionality of Core i7 CPUs. In addition, modules are tested in matched triplets ensuring superior compatibility.
OCZ’s Triple Channel kits are 100% hand-tested for quality assurance and compatibility and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory module is backed by the industry leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 1333MHz DDR3
- CL 9-9-9-20 (CAS-TRCD-TRP-TRAS)
- Available in 3GB, 6GB, and 12GB Triple Channel Optimized kits
- Gold Z3 XTC Heatspreader**
- Lifetime Warranty
- 1.65 Volts
- 240 Pin DIMM
Was [£104.99] Inc. VAT
Only £82.24 inc VAT.
ORDER NOW
OCZ Gold Low Voltage 12GB (3x4GB) DDR3 PC3-10666C9 1333MHz Triple Channel (OCZ3G1333LV12GK) @ £199.99 inc VAT
- 1333MHz DDR3
- Available in 4GB modules and 12GB kits
- Unbuffered
- 1.65 Volts
- Lifetime Warranty
Was [£234.99] Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
OCZ Gold 4GB (2x2GB) DDR3 PC3-16000C10 2000MHz Dual Channel Kit (OCZ3G2000LV4GK) @ £82.24 inc VAT
OCZ low-voltage DDR3 kits are designed specifically for the Intel® P55 Chipset and subsequent Intel® Core™ i7, i5, and i3 (Socket 1156) processors. Configured for dual channel mode, these ultra-compatible 4GB kits ensure optimal performance with an ideal combination of low power requirements at 2000MHz.
Developed for cost-conscious enthusiasts and gamers, these new OCZ modules were engineered with the same affordability and performance standards as the new Lynnfield platform. By using sophisticated IC screening methods and qualifying on a variety of motherboards, OCZ low-voltage kits are the perfect complement for the P55 Chipset and choice CPU to deliver the maximum stability. Together, P55 and OCZ memory are the premium option for the midrange desktops.
OCZ DDR3 PC3-16000 Gold Low Voltage Dual Channel Kits are 100% hand-tested for quality assurance and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory kit is backed by the industry-leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 2000MHz DDR3
- CL 10-10-10-30 (CAS-TRCD-TRP-TRAS)
- Available in 4GB optimized kits
- Unbuffered
- Gold Layered Z3 XTC Heatspreader*
- Lifetime Warranty
- 1.65 Volts**
- 240 Pin DIMMPart Numbers
Was [£99.99] Inc. VAT
ORDER NOW
OCZ Reaper Low-Latency 4GB (2x2GB) DDR3 PC3-12800C6 1600MHz Dual-Channel (OCZ3RPR1600C6LV4GK) @ £79.99 inc VAT
OCZ low-voltage DDR3 kits are designed specifically for the Intel® P55 Chipset and subsequent Intel® Core™ i7, i5, and i3 (Socket 1156) processors. Configured for dual channel mode, these ultra-compatible 4GB kits ensure optimal performance with an ideal combination of low power requirements and tight CL6 timings at 1600MHz.
Developed for speed-hungry enthusiasts and gamers with overclocking on the mind, these new OCZ modules were engineered with the same performance standards as the new Lynnfield platform. By using sophisticated IC screening methods and qualifying on a variety of motherboards, OCZ low-voltage kits are the perfect complement for the P55 Chipset and choice CPU to deliver the maximum stability. Together, P55 and OCZ memory are the premium option for desktops.
OCZ DDR3 PC3-12800 Reaper Low Voltage Dual Channel Kits are 100% hand-tested for quality assurance and feature propriety Reaper HPC Heatsink for the most effective heat dissipation. Furthermore, each OCZ memory kit is backed by the industry-leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 1600MHz DDR3
- CL 6-8-6-24 (CAS-TRCD-TRP-TRAS)
- Unbuffered
- Lifetime Warranty
- 1.65 Volts
Was [£89.99] Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
OCZ Gold 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (OCZ3G1600LV4GK) @ £59.98 inc VAT
OCZ low-voltage DDR3 kits are designed specifically for the Intel® P55 Chipset and subsequent Intel® Core™ i7, i5, and i3 (Socket 1156) processors. Configured for dual channel mode, these ultra-compatible 4GB kits ensure optimal performance with an ideal combination of low power requirements at 1600MHz. Developed for cost-conscious enthusiasts and gamers, these new OCZ modules were engineered with the same affordability and performance standards as the new Lynnfield platform. By using sophisticated IC screening methods and qualifying on a variety of motherboards, OCZ low-voltage kits are the perfect complement for the P55 Chipset and choice CPU to deliver the maximum stability. Together, P55 and OCZ memory are the premium option for the midrange desktops. OCZ DDR3 PC3-12800 Gold Low Voltage Dual Channel Kits are 100% hand-tested for quality assurance and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory kit is backed by the industry-leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 1600MHz DDR3
- CL 8-8-8-24
- Unbuffered
- Lifetime Warranty
- 1.65 Volts
- 240 Pin DIMM
Was [£74.99] Inc. VAT
Only £59.98 inc VAT.
ORDER NOW
OCZ Platinum 8GB (2x4GB) DDR3 PC3-12800C7 1600MHz Dual Channel Kit (OCZ3P1600LV8GK) @ £182.11 inc VAT
Configured for dual channel mode, these ultra-compatible 8GB kits ensure optimal performance with an ideal combination of low power requirements at 1600MHz. Developed for cost-conscious enthusiasts and gamers, these new OCZ modules were engineered with the same affordability and performance standards as the latest Intel and AMD platforms. By using sophisticated IC screening methods and qualifying on a variety of motherboards, OCZ low-voltage kits are the perfect complement for the Intel P55 and AMD 8 Series Chipsets to deliver the maximum stability.
OCZ DDR3 PC3-12800 Platinum Low Voltage Dual Channel Kits are 100% hand-tested for quality assurance and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory kit is backed by the industry-leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
Features:-
- 1600MHz DDR3
- Unbuffered
- Platinum Layered Z3 XTC Heatspreader
- Lifetime Warranty
- 1.65 Volts
- Qualified on Intel P55 Chipsets and Core i3, i5, i7 CPUs
- Qualified on AMD 8 Series (Phenom X6 CPUs only)
- 240 Pin DIMM
- Lifetime Warranty
Was [£199.99] Inc. VAT
Only £182.11 inc VAT.
ORDER NOW
OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Dual Channel (OCZ3G1333LV4GK) @ £58.74 inc VAT
OCZ low-voltage DDR3 kits are designed specifically for the upcoming Intel® P55 Chipset and subsequent Intel® Core™ i7, i5, and i3 (Socket 1156) processors. Configured for dual channel mode, these ultra-compatible 4GB kits ensure optimal performance with an ideal combination of low power requirements at 1333MHz.
OCZ DDR3 PC3-10666 Gold Low Voltage Dual Channel Kits are 100% hand-tested for quality assurance and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory kit is backed by the industry-leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 1333MHz DDR3
- Lifetime Warranty
- 1.65 Volts
- 240 Pin DIMM
Was [£59.99] Inc. VAT
Only £58.74 inc VAT.
ORDER NOW
4GB Dimms are gonna get more mainstream I imagine now. Some very good prices on those.
Yeah definitely, 4gb sticks are starting to creep out at reasonable prices.
Good prices on some of those, shame my system is on ddr2 and I don't want to upgrade before sandy bridge :(
Certainly big discounts but I don't think I can go for another 12 GB until it can be had for £160 or less. Might be waiting a while but oh well. :)
