Quick question about wall mounting Onkyo HT-S3305 speakers
alx
alx
10 Aug 2003
Dubai, UAE
Quick question, if I was to get a Onkyo HT-S3305 5.1 system, would I need wall mounting brackets like these (linky) for the speakers or can you wall mount them straight off?
I believe the rear speakers have a grove so you can mount them on the wall with a screw to hang on, but remember if you do that you won't be able to angle them in any direction to improve the sound quality.
If you look on the bay, you can get some standard wall mounts and use a screw fixing to support the speaker. There's a sort of hole on the back that the screw can slot into. Sorry for the vague description but that's the only way I can describe it :) hope this helps!
