Yeah it is, but you would have to use a mobo with the Lucid hydra Chip. and IMO it's not worth the gains you may see going this way, sell the 4870 on.
it is with the Lucid hydra Chip you can mix any gpu nvidia or amd of any series
Mr. May.it is with the Lucid hydra Chip you can mix any gpu nvidia or amd of any series
Mr May.x-fire,Lucid, sli are all multi gpu rendering so it is all technialy the same thing by dirrebt companys and Lucid is built into some off the new motherboards which are coming out
there is a review about it below
http://www.guru3d.com/article/msi-big-bang-fuzion-lucid-hydra-review-test/
