Hi I am wondering if my psu would prob be enough to run a asus gtx 580 and also enough power to overclock
Reason i ask is i have tried in past using 2 x 5870s in crossfire and even got chance to test a ares 5870 4gb and both of them resulted in my pc screen going blank and making a loud noise like its struggling to power
This i discovered through forums that my psu cant cope
My setup that id be adding this to would be a i7 oc to 3.6 with 6gb ram a ssd drive and 2 standard hd and a bluray drive
At moment i have a 5870 which runs perfect even at high overclocks i get 950 is most stable with voltage tweaks
But anyway main question is would my 800 watt tagan turbo psu support this card with no issues even though its min spec is 600 watt is that the recommendation for the card alone without the extra components ie i reck my i7 oc to 3.5 prob uses quite a lot
Thanks any advice be helpful
