5870 Pc Wont Boot.
21 Nov 2010
Hi All
Specs Win7 Pro 64Bit
I7 920
Rampage 3 Mobo.
1000k Antec Psu
6gb ddr3 Ram
New Graphic card will not work cant boot windows when driver installed works fine without driver.
Have had it working fist time of use in Crossfire. after a pc restart then no even with card on its own.
Both cards are in Device manager.
Cards His 5870 1GB and Sapphire 5870 1GB
Tried
New and Old Ati Drivers
Fresh Win7 Install
Driver Sweeper Cleaner
Change of PCI E Slots
Bios Update
Thanks in Advance.
Bradley
Does the M/board have its own output? if yes try just that.
Second, use windows 7 generic drivers for the cards.
Try one card at a time.
What psu do you have?
Driver sweeper will just make things worse so I'd suggest not using it again. If it's still causing problems after a fresh install of Windows, I'd suggest that it's either a BIOS issue or the card is borked.
Hi
what can i do about the bios issue and I'm sure it is that due to getting a Bios Boot message asking for a bios Flash from Cd Rom Floppy Usb etc at startup.
Thanks for the replys.
Hi Mate thanks for the reply.
I have tried that before still not working.
First time i ever used it was in CF and it worked then after a PC restart no.
Would it work at all if it is faulty from Overclockers?
You did do it correctly didnt you? hmmmm load defaults in the bios. If you cant you can also use the reset button on the mobo. tried both cards by them selves? also do you mean you can boot into windows without the drivers installed? did you try to overclock your cards?
I did do it right.my older card works new one no on there own.I've no problem starting windows with both cards in though only without ATI Drivers installed and then the resolution is poor.
I overclocked my older Card with MSI Burner though since formatted my PC is it still OC.
