Hi all,
I'm looking for a good headset to go with a Xonar DG (Seeing as that gets good reviews, and the prices seems great).
I used to have Speedlink Medusas and loved them, especially the bass, i also thought the sound quality was good from them. (Limited experience though!)
Main things im wanting is 5.1 surround and an attached mic. Ive done a bit of reading around about the differences between real surround and virtualised, but im still not 100% clear on which is the better option. Any advice on this also would be great
Budget for the headset is around £60-70, might go a little bit higher if there is a really good option just above that price.
As im sure you can tell im a total sound newbie, so any help / advice would be great.
Thanks
Thanks
Which is no bad thing at all.
