I did that. Last night I loaded optimized defaults.. no OCing on the q6600. And still got the signal lost after an hour or two. It only happens when I OC the card. If I leave the 470gtx at standard clocks and up the cpu. No problems.
Weird. Maybe my psu isn't handling the extra voltage well? Should I force the voltage to stay constant using Afterburner? What you think?
(tho normally not enough vcore would result in crashing or corruption rather than just dropping out).
