Looking for those Corsair Cable Management Grommit things...
13 Sep 2009
Maidstone, Kent
I am doing a HAF932 mod and those grommit things that go over the cable management holes on the Corsair/ HAF X cases just look the business. Does anyone know where I can get them, looking for the exact ones really, does anyone know where I should start looking. Considered blagging some from Corsair but they are very difficult to get hold of. Some ideas would be nice.
I took a full set off a 600T that got burned up in a fire. In perfection condition. I don't know if the length of the grommets will be a good fit for a HAF932 but whoever wants them can have them for free. I can post them tomorrow, though I'm not sure how long they will take to arrive in the UK, as I'm in Ireland.
I only have 1 set so whoever posts here 1st, it's theres.
TUNSTALL_NICK - I posted them an hour ago. Hopefully you will get them by the end of week although post from Ireland to the UK and vice versa seems to be a little slower now this time of the year.
cheers
That's a good idea actually. Although the blowhole trim stuff is a little bit flimsy compared to the corsair gromits, but a good idea none the less.
A bit of uhu glue. to stick it in place will sort that out.
And with trim you can be quite creative about your cut out holes.
Electrical wholesale/trade store will do round grommets various diameters for 20-70p pence each.
Yep that the stuff - same as an open grommit
if you wanted a closed grommit then it's no good.
But you can cut keyhole/triangle shapes so each molex/22 pin socket fits the larger part one at a time.
But all the cables when threaded, are at the smaller end.
You could even get a round closed grommit to seal the larger hole if you wanted.
